vetteboy
- morganville, nj
Goatman said:With the load reactive valve and return to center, does it return to center with the single ended cylinder each time, or does the centering move a little as the steering wheel moves a little? If so, how do you get it back? I wouldn't care about the steering wheel moving around, but what about the return to center?
IIRC, the load reactive part of the orbital means that the little torsion rod can be activated by pressure feeding back from the ram, and then spin the wheel. The returning part comes from your standard caster/ball joint inclination just as a mechanical system does. The steering wheel center and actual center aren't mechanically related at all so there's no real adjustment to be had there. If you were really anal about it you could put some sort of set screw on the orbital valve to be able to set the wheel independent of the orbital, but it would be off again after a few good hard-lock turns - anything from pushing some fluid past the pump bypass, to getting some air bubbles in there from agitation, to fluid expansion from heat can cause this.
