Paul, I measured from the outside lip of the steel wheel (widest part of the wheel) to the edge of the Tera arm even with the lip of the wheel and it's 1 3/4". The bead of the alloy wheel is thicker than the steel wheel, but the steel wheel has that lip on the edge of the bead, so it should be about the same. My wheels are 2.5" backspacing.
I'm wondering about this arm correction issue.....that it might not be a bad thing. The D44 arm tilts inward, so a flat arm really makes the DL joint angle severe. They add correction to flatten the mounting surface for the links. With the inverted T like I'm running on the yellow XJ the only thing that matters is the tie rod mounting surface, so while my arm has correction, it should work fine without it. If we're now going to mount the DL directly to the arm, then if we use an arm with correction the angle of the DL joint will actually be less than it would if the arm was flat (since unlike a D44 knuckle, the top of our Tera knuckles are flat/level). With correction, the tie rod mount would have some angle in it, but the tie rod joint only spins, while the DL joint has to move. So, which is better, having a flat mounting surface (relative to the link) for the DL or for the TR? It should be better to have less angle on the DL since DL joint binding can be an issue. If that's the case, then we could use anyone's arm that will put the link holes where we want them, and we could use a raised arm to get a little more clearance.
AND, how important is the best Ackerman angle? It looks like the Tera arm will have the best Ackerman angle, but plenty of folks are running the other arms, including us on our D44's, and they seem to work fine.
I keep switching back and forth between the issues involved. Tie rod as high as possible above the arm but more forward to clear the pitman arm and in front of the drag link (but then the ram has to go behind the axle on a double arm). Tie rod lower below the arm and as far rearward as possible, directly below the DL, would have to use rod ends and can't use my aluminum DL and TR, but the current mount and position of the ram would work. TR below the arm and slightly forward of the DL and keep the 1 ton TRE's and the aluminum links, and the current ram position will work. Then......Tera flat arm made of 3/4" plate with good Ackerman, or a raised arm made from much thicker billet with correction (that probably doesn't matter) but not as good Ackerman angle. ????
