blondejoncherokee
- sacramento
So if the MC supposed to seal to the brake booster ? the 96 junkyard booster and reman 78 grand marquis master combo has horrible breaks. I have verified the MC is holding pressure, and also tested the booster and verified its not working. I feel like there is a slight gap between the booster and master. brakes are horrible. I might just put the WJ setup back on. Anyway, For shits and giggles I RTVed the MC and the booster where they seal to see if that helps and ill check it tomorrow.
wilwood prop valve and electric line lock:
longer push rod for the booster to MC :
