Under heavy braking the fronts do up to 85% of the braking, and on some other sources online they say up to 90% of the braking, due to the weight transfer. The front end suspension compresses, the rear end comes up, the rear brakes with much less weight begin to lock up early. Add a high COG and that makes everything worse.
Here is some good reading, go to the proportioning valve section:
http://www.pirate4x4.com/tech/billavista/Brakes/
"As the brakes are applied, full pressure is allowed to the rear up to a certain point. Beyond that point, the pressure to the rear increases at a reduced rate, preventing rear brake lock up. "
its almost like my Big rear discs would help to have smaller calipers and smaller rotors . So it seems to me that massive rear brakes are not always a great thing. I might end up having to find smaller rear calipers.
I still need to drop the rear end down an 1" or two. I am thinking of raising the rear shackle mount 1/2" to 1.5" higher, whatever fits, and also maybe running a shorter shackle by 1/2" to 3/4" shorter as well. Ill see where that gets me, if thats not enough, ill try pulling a leaf out.
