outlander
- Columbus,Ohio
Ok who has this steering system in stock and not Back ordered....I finally scrapped up enough cash.
chris420 said:Dude you need to buy the Currie Rock Jock steering system. I just instaled mine last weekend and it is bad ass. The tie rod and drag link are the same size as my buddies F250 and they are solid stock nut tube. The tie rod ends are a lot bigger than the stock one's to. I purchased the tie rod flip insert from goferit products and flipped the tie rod. I think it was the best investment I have ever made for my XJ.
Basically no one. Manufacturer has a backorder of 79 right now.outlander said:Ok who has this steering system in stock and not Back ordered....I finally scrapped up enough cash.
RCP Phx said:Bottom line,we have not gotten this kit to work.Three spacers still dont work,buy something else!
mage said:I have this streering set up with a RE 3.5" lift.. blew out the grease boot on TRE to the pitman... severe angle I guess... will a drop pitman fix this angle or will a drop screw up my streering angles?
dellstopjeep said:well i had just gotten the jeep aligned, trackbar, steering and long arms and was driving home and kit felt okay with spacer, I think my stock steering handled better. IMO if your over 5 inches of lift this is not the kit for you if I could go back again I would have went jcr or another route. Didnt get much testing though since a couple miles down the road my jeep starting pulling hard to the right and smokin from passenger rotor like crazy, think caliper is stuck or something
