- San Juan Ridge, CA
OK great. so are on the same page. Good. let us know where its at . if your pinion angle is too good looking, and you're at 4.5 "+ lift, then you possibly have a caster issue. possibly. once you measure and figure it out, adjust your upper arms in equally - one at a time or use a pipe wrench on a floor jack to the axle tube to keep it from rotating up.
Thanks Jon the floor jack/pipe wrench worked great. The rig is sitting at +5* now and seems to be fine but I wont know for sure until I can get it to the Hwy and get it past 60mph.
I put a 45mm socket over the top of the ball joint and used that to find my angle. Both worked great.
