tayman said:you know that's a very good point. I'm not saying that I don't rub... I rub a little at full stuff with stock bumpstops. I'm just sayin that it's probably not enough to fret about.
JAS said:Ever consider loosing the stock flairs?
Up front you gain over an inch in the wheel wells without trimming. I loaded up the flair mounting holes with a stainless 1/4-20-x 1/2 bolt that also holds up the fender liner and such.
Outback it is about 1/2 inch-ish. But be warned there is the body locating hole that is about 3/4 inch that sticks down into the wheel well that will need some trimming. You can just see it in the water pic in the rear wheel well.
Here are some picks of a 97 without flairs and without bumper end caps. I have and RE 3.5 inch Super flex up front and Dak Pak outback for about 4 inches of lift
I have not been out wheeling since loosing the bumper end caps.
XJCruiser said:here in PA we have to have the flares on if the vehicle came with them from factory....PITA
If your running on the road disconnected, and losing flares...why not just re-connect the sway bar??? :dunno:XJCruiser said:but im getting most of my rubbing when disconnected on the road while hitting bumps and cornering my passenger side flare ripped right through the screw holding it in place ive had to pick it up off of the road 4 times in the past week or so...
TRAILREADYXJ said:If your running on the road disconnected, and losing flares...why not just re-connect the sway bar??? :dunno:
Where is it actually rubbing on the flair? For example, If it is hitting the rear, and the wheel isn't centered in the wheel well (when stuffed), your control arm length is wrong. If it's centered and hitting the top, you need bumpstops or trimming.
massscene said:what size tires are those?
XJCruiser said:both wheels are centered and yet rubbing in the rear on the bottom
Dan96XJ said:does it rub when you turn? i would've thought it was the BS in the rims now at 3.75 will stick out further and therefore interfere with the rear bottom bit, as it should clear with stock BS. I never had it rub there on stock rims 31s and 2.5" lift. i have 4.5" lift now with stock rims 31s, still no rubbing. i was sizing up my new rims (3.75 BS) with 33s the other day, and it was that first spot i realised it will rub esp. on turning. Grinder is my new best friend.
tayman said:My decision to trim stuff was easy... when you pay $550 for the jeep, you don't care nearly as much...
massscene said:G The 31's dont seem to be holding you back at all.
XJCruiser said:i paid under 4K but it was in near mint condidtion when i bought it....garage kept and everything...til i bought it...now sits outside....been shot twice with a bb gun by some kids, off roaded....but id say its still 95%+....ive put so much money mechanically into it in the past two years though, it isnt even funny....i was hoping to make it to NACFest this year....doubt that will happen
tayman said:that makes perfect sense. you should be able to get away with very little trimming. My 31's rub ever so slightly at full stuff. with almost no (fender) trimming. Now, you are lifted higher than I am, which means your axle is pulled slightly farther backward. Is your rubbing occurrinig only while turning, flexing, or turning while flexing? Or is it all the time?
