That'll work ok but, you should weld a tube (sleeve) into the bumper to keep from "crushing" the rectangular tubeDanMan2k06 said:^ Learn to read... There will be a bracket that captures the carrier. Almost like a sandwhich. And the bolt goes all the way through the bumper... whereas most are just butt-welded on top of the bumper. Hence "flagpole"... a flagpole just sits on top of the ground.
Those are made by: www.destacoclamp.com You can get them from: www.mcmaster.com (look under toggle clamps) they can usually have them delivered to you by the next day----------HansDanMan2k06 said:........Where do you guys get your toggle pull latches? Anywhere locally? I checked Home Depot, Lowes, Ace, Tru Value, Tractor Supply, Southern States, Napa, Pep Boys, Wal-Mart, all with absolutely NOTHING!!
Jeeps in Head said:Damn nice bumper jdbwrx.
DanMan2k06 said:Well I made some progress tonight, I pretty much have the bracket design figured out. I'm using 2.0x4.0x1/8 tubing, which will push all the way into the frame, and bolt in underneath, as well as the stock locations. I also cut a slot down the tubing so that the shackle bolt slides in nicely. I don't think it should have any effect on overall integrity. Heres some pics.
Heres the 4 holes.
Heres what I had to cut out to get the tube to fit
Like a glove
Heres the slot
A few holes drilled
And of course a look down the tube to see how it all lines up.
The nuts will be welded inside the tube, and then bolts will be used to secure everything to the frame. I should have more pics on the stock flange/plate in a few.
SOUTHTEXASXJ said:Whats it made of?
dgrigorenko said:does anyone know what size tube this is? i think i am going to build a bumper and use this mounting system.
