Projects to complete before NAC-Fest....
New update:
1. Have rotted/rusted rockers replaced with HD tubing Done!!
1a. (New) Put coat of Rustoleum over primer on new rockers (waiting for warm weekend)
2. Have rusted rear quarter panels addressed Done!!
3. Replace mangled OEM transfer case crossmember
4. Install HD tie rod from recent Group Buy
5. Select/Acquire/Install new front bumper with integrated recovery points (my Rusty's tow hook brackets have been structurally compromised)
6. Fix my homebrew power mirror harness (outstanding from pre-Moab, it's annoying me because it worked fine all summer until the carpet was reinstalled three days before I hit the road for the 25th)
7. Tweak adjustment on my auto deflators
8. Redo power wiring on my Tsunami compressor before it pulls completely out of the fuse holder
8. Watch the rest of the NACFest 2008 videos (got as far as me crossing of Rock Creek on Disc 1)
9. (New) Order/Install replacement diff cover on rear axle to replace peeling OEM - Ordered/Shipped (man, Dan's fast on the draw!)
10. Coordinate meeting with MrShaft696 (he's buying my C4x4 rock rails) In Process
11. Register Done!!
Definitely one of the best vendors for fast customer service. I once placed an order with him online and he called me less than a minute later with a few questions and to tell me it would ship that afternoon. :D
My endless list of crap to do..
1) replace upper and lower ball joints- DONE
2) replace my LCA's
3) drill/tap new holes for rear bumpstops and put them back in: DOING THIS WEEKEND
4) Get 4.56 gears installed in the D30 and D44- just ordered gears/install kits today from national drivetrain :)
5) Get ARB installed in the 44
6) disc conversion on the D44 (hopefully)
7) make up some brackets to bolt my sub down so it doesnt slide around: DOING THIS WEEKEND ALSO
8) get a transfer case skidplate and sye and install them
9) install gas tank skid plate
10) get OBA done
Also, need to do a few more things...
11.) Replace coils
12.) replace steering box & steering shaft
I'm not getting too far on my list either...most of it is stuff I can't do at school so I'm gonna have to wait til I go home in a few weeks.
hah I just noticed i had 2 broken leafs! one on each side, same one. So I picked up some s10 leafs used yesterday and I am going to have to re-do the spring pack yet again.
Nutting seps routine maintenance.:clap:
I need to remove an inch-think layer of coal mud from my entire vehicle. To me this is a more daunting and crappy task than most of the mods I've done to the damn thing.
Prerunning/racing at Rausch is dirty work, but someone's gotta do it. :D
Yay, I can actually do this.
Hmm, lets see.
Get it driving first - It drove to Foxboro yesterday
Replace steering box - Done
Plate frame rails - Might not happen
Modify and install gas tank skid
Take ARB bullbar off and redo mounts/cut for clearance/ sink lights into bumper - Bumper is cut apart, holes made, brackets and everything are done, it just has to get welded all up
Install/hard wire winch - Will happen once bumper gets back together, now that the winch can actually fit in there again
Build rear bumper/tire carrier
Modify Slickrock Gear quarterpanel guards and add integrated tail light boxes
Find out what bearings are making noise in rear axle and replace
Remove t-case and clean/fix or probably replace
Remove the broken crossmember bolt from the unirail so I can have more than 3 bolts holding it on.
New crossmember/skid - Picking one up in a couple of hours
Get new upper ball joint sleeve to fix camber issue
Get 2 screws to screw the rear OX lever face down, so I don't have to hold my rear OX engaged
Fix the trackbar RE superflex joint that RE keeps sending me the wrong/poor quality parts for
New headlights/wire harness/fitchbox - partially done
Buy new tow straps, and only pull people if they have d-ring shackles.
*cough*cough* Don't you have long arms to install?? *cough*cough*
haha I asked the same last time I saw him & he gave me run around haha... Nac fest 2010 maybe..
Whaddya know, I have another update!
5. Select/Acquire/Install new front bumper with integrated recovery points (my Rusty's tow hook brackets have been structurally compromised) Trigger pulled - bumper is on order
5a. (New) Pick color to paint bumper when it arrives
5b. (New) Paint the doggone thing.
11. Register Done!![/quote]
Gettin closer...
1. Lower the XJ a little (cut the front springs, and rebuild the rear leafs)Done
2. Put in the gauge package into the XJ, change sensors DONE
3. Change the CPS in the XJ (can you tell which Jeep is getting neglected?) Done
4. Put a winch bumper/winch on the MJ. Got the winch bumper, need to paint/mount
5. Figure out rear shock mounts on the XJ-- Design done, tying it into the existing cage.... gonna be bada$$
Move to NH Kind of done (most of our stuff is there)
'96 XJ:
Swap tires on to my beadlocks
Install Suckdown winch
Install New steering
Frame Stiffners
'87 XJ
Wire for the winch
Install Hitch to replace pretzeled rear tow hook
Replace floors and bedline if I have time
I still have lots to do...
Okay, I finally fixed the ARB compressor, so my heep dose'nt sound like it's farting every 5 minutes.:passgas: ( had a few leaks to take care of ).
if your done, go take of your doors or something
upper control arms
lower control arms
trackbar
shocks
rear locker and axle swap-DONE!
tcase skid
brakelines-rears done, need to order frts
DONT ROLL IT!
crossed off a few things today, but got a couple more to add
frt bumper
frt brakelines
motor&trans mounts
Rain over the last week took care of most of my mud situation.
The remainder can wait until after wheelin next weekend, because it's supposed to be a sloppy mess out there again. I think I like this excuse because you can always find somewhere at Rausch that is a sloppy mess.
I had some pretty bad rattles and clanks, turned out to be nothing more than a few loose jam nuts and johnny joint bolts that hadn't seen a wrench since April 2007. Guess all this 'high speed' stuff is finally knocking some things loose. Good to go!
Time to start trying to generate a list again.
