- Michigan
How about the t case linkage? You put that in yet?
Big fan of this.If you have the means, I highly suggest you pick one up. They are so choice.
Also a big fan of this!So far I have ~$150 in this thing out of pocket.
Yes, Novak cable linkage.
I'm jealous.
Also, I'm in need of a 96/older center console. The one in it was trashed, and the 97+ will take modification to work. If I can find a cheap older one to drop in for now that's what I will do.
Maybe wanna put a PM in to Ken. I would bet he won't read this thread. I think Important is all he goes into.Edit: Question: Does the CPS control the tach signal? Before the trans swap the tach read correctly at idle. Now it reads low; at idle the needle is at the line right above zero. The engine is idling normally. It's not a huge deal, but I get particular about gauge readings for some reason.
What color? I've got a one in tan.
JIM.
It's home. Drives like... a lifted Jeep. Need to clearance the spring perch a bit for the shock, the PO welded the shock mount too close so the shock body is touching, which I think is the cause of the noise I hear in the rear over bumps. Everything else is tight and good to go. Speedo doesn't work either, not sure if I have the gear wheel clocked right or what.
Probably take a bit to add the goodies, priority was to get it streetable since the pickup is down for now.
I never plugged in the speed sensor. lol It was too short.
I plugged it in. Not quite banjo string tight, but close
i saw rusty's and threw up in my mouth a little....just sayin
.....wheres that edit button
