Nely87
- California
What color is the interior? I need the driverside seat belt
i need a tank for my 96 will it bolt up how much ?
I want the 2wd beam axle. How much?
I need the headliner, sending PM now...
Cockspring with cruise control?
Put me in line for the tank.
Still have the tail lights? Sign me up if you do.
I only need the beam for a few weeks to mock up brackets for a D44HP after that I can pass it on to Goatman
If you only need the tank Ill take the fuel pump since a 96 is different.
Looking for a driver floor pan and Transmission crossmember.
yeah i just need the tank
Dan, if you just need a non-leaking tank, you can have mine once I swap in the non dented one...The 1996 tank is different than the 2001 tank.
Also be aware that the 1996 fuel pump is a one-off design, 1995 and 1997 differed. I believe the tank is unchanged though (so any 1984 - 1996 20 gallon tank should work, I'm not sure if the old 15 gallon one will work with that pump).
