Bugboy
- lancaster , Pa
You can get a setup like this for about 25-30. it has everything you need to convert with exceptions of the fittings.
you can basically just mount it to the air tank if you want and use the regulator if you want but i seperated the whole thing. I have a t on the air tank with a gauge and a 150 popoff. I took the pressure switch(85-135) off and mounted that via a T off the compressor. along with a gauge and check valve and another 150 psi popoff for emergency. you just run the hook a switch up to the compressor with the pressure switch and it will tunr the compressor on and off as needed.
![halloween008.jpg](/proxy.php?image=http%3A%2F%2Fi308.photobucket.com%2Falbums%2Fkk322%2FBugboy115%2Fhalloween008.jpg&hash=4adf5626bf9b38797bf47db943300621)
