OEM part numbers for XJ
nated0g
Memphis TN
Posting this just to get some information.
I have a 89 xj with bad dead spot and my rod ends are shot.
did some research and found some part numbers and wanted to post/had questions.
xj
http://www.cyberjeep.com/products.asp?dept=5603
52000598 TIE ROD END - LEFT (DRIVER SIDE)
52000596 TUBE - LEFT END TO TIE ROD
52000596K TIE ROD KIT - KNUCKLE TO TIE ROD
52000599 TIE ROD END - TO INNER TIE ROD
52000608 TIE ROD END - AT PITMAN ARM
52000604 TUBE - TIE ROD TO LEFT END
52000601 TIE ROD - TO RIGHT KNUCKLE
zj v8
http://www.cyberjeep.com/products.asp?dept=5606
52005739 TIE ROD END - LEFT (DRIVER SIDE)
52037536 TUBE - TIE ROD TO LEFT END
52037996 TIE ROD - LEFT END TO CENTER
52005739 TIE ROD END - AT PITMAN ARM
52037536 TUBE - TIE ROD TO PITMAN END
52037994 TIE ROD (DRAG LINK) - FROM RIGHT KNUCKLE
OK have questions, do yall :yes im from the south: replace the whole assembly. I noticed that the draglink is the same style but for the v8 the tie rod is the same style at one end as the draglink...1 attached at the end.
Im sure ican take these part numbers to a parts store but does anyone know or have the way to convert to "parts counter idiot" part numbers?
Nathan
www.napaonline.com great parts type it in where it says non napa part #
they have it in both lines
Tie Rod End MRC ES3096 52005739
$21.99
