Need Help.. Need JKS bolt measurement!!! HELP!!!
There is not a *bolt* that goes thru the shock bushing on a JKS BPE.
If you were copying a set you would use a 5/8" bolt to go thru the bushing.
mark
orgs mfg
well... what I'm looking for is the size of whatever you wanna call that thing that goes through the middle as I might have to get a set to have it work with whatever shocks I get out of Rancho to replace the ones that have bad length on them.... so in any case, that "whatchyamacallit" that goes through is 5/8" or for a 5/8" shock??? is is meant to go through a sleeve or directly through a bushing?
Thanks
The shaft that goes thru the bushing is 5/8".
All eb1 shock bushing (most common) has a 5/8" hole in it.
mark
orgs mfg
Kejtar said:
thanks Mark... that's twice you have saved my skin this week :D I owe you a nice cold one at Moab :D
Kejtar
As long as it is one you've brought from home. NO UTAH BEER!
mark
