Well, break has been over for a little while now... Its about time I update this.
Here is my to-do list from over break:
- New steering/track bar made of 1.5" .25 wall DOM w/hiems, OTK.
- Build new crossmember
- Install long arms (on new crossmember^)
- Weld on T&T Customs frame stiffeners
- Fine tune shackle angle (or if I have enough time... )
- New shocks
- SYE
I wasn't able to get nearly as much done as I had hoped. I ended up working many many more hours than I had originally estimated, which isn't entirely a bad thing.
First, I threw the stock shackles back into my relocation brackets to lower the rear a bit and get rid of some driveline vibes. I plan on putting the longer shackles back on soon, but I have to pull a leaf spring or two out first.
Then I was able to get my steering buttoned up, however I will be changing it up as soon as I can. With the drag link mounted directly onto the tie rod, the drag link rotates the tie rod front and back when I turn left and right (even when the jam nuts are well... jammed). I am also battling tie rod roll issues (leading to death wobble), and my current fix keeps my steering from naturally returning to center while on the road.
Heres the best shot I can find of the steering as it is now. Thanks to Josh for the photo:
To fix my issues, I will be moving the tie rod under the knuckle, and running my drag link all the way out to the top of the knuckle.
I would like to give a big thanks to my new friends at J&J Welding in Pleasanton. They do great work, are very flexible on their hours, and are fellow wheelers themselves. They helped button my steering up the night before I left to wheel at Hollister. They flexed it out and aligned it as well. Top notch work, service, and very reasonable pricing.
Speaking of wheeling at Hollister, I met up with Tim, Josh, and his brother Nate and tested it all out. Unfortunately I forgot my camera, so all photo courtesy goes to Josh and Tim:
Jungle Trail:
Eating at the top:
Truck hill (in reverse) muahahaha:
And the White Rock climb:
I had a great time out there and cant wait to go back again!
So that brings this back up to speed. I have a hack-n-tap SYE sitting in the garage, as well as Tim's old long arms and crossmember. Frame stiffeners will be finish welded ASAP, and then I will try to figure out the shock situation.
Lastly, I was able to make it out to Tim's fun factory for a meet and greet. I had a great time out there, and it was great meeting so many new people! I hope to see you all again soon!
