Finally, an answer... Thanks BarFlyFisherman. Where did you find the information?
I am running the Ford 8c607 series fan as the prime fan. According to Ford, it is a 3800cfm fan at 14VDC. I run it on low to keep air moving across the alternator using the Ford fan dropping resistor. It switches to high speed when the controller calls for fan. I have also rewired the stock fan to come on when either the controller of the A/C calls for fan. Lifted the entire Ford setup, relays and wire and all, fromt the local u-pull-and-pay. Cost about $30 for the lot. My Heep operates between 194F and 201F all day, every day. I am using a 180 T-Stat and a controller on the electric water pump which allows the engine to get to temp. I only run a T-Stat to decrease warm up time. Otherwise, it would not be needed.
