winterbeater
- Royal Oak, Michigan
Stacked plate cools better, but tube/fin is more robust. (I worked in OEM cooling systems warranty.)
Techno from what I've read the stacked plate cools Better(this is coming mostly from the people who use the stacked plate though). Wish I could link the cooler I want to use from summit. If you do a search of that part number it should come up.
Stewie, What cooler did you use?
I am a little bit turned off by the 'staked plate' type. I thing the tube and fin type may be better but I have no data to support my assumptions.
i used a fin and tube one from NAPA
Does anybody know how much CFM the stock mechanical fan pulls at idle(warm/cold)? I'm looking to maybe go another route for my tranny cooler but am wondering if the stock fan clutch will pull more CFM.
TIA guys,
Sean
Just to jump back to your original question, would increasing the CFM of the mechanical fan get you where you want to be?
Asking because the ZJ HD fan clutch provides a tremendous improvement in air flow. NAPA part number 272310 about $62.
I think if you search some other threads on the HD fan clutch changes, some people have changed back to stock because of the fan noise. Not saying don't do it just to research it some before you spend the money/time.
Would the ZJ clutch use more gas on the freeway, or is it pretty much freewheeling with good natural airflow?
Its disengaged (freewheel?) speed is the same as the stock, 20 to 30 percent of shaft speed, so there would be zero effect on mileage.
When engaged it spins at 80 to 90 percent of shaft speed versus 60 to 70 percent for the stock clutch.
