87baseomatic
- North Jersey
Hello all, trying to figure out what’s up with the air conditioning on my father’s 01 XJ. Quick background, he’s owned the truck since 2004, has 170K on it now. I installed a reman compressor roughly 70K miles ago. I replaced the condenser about a decade ago due to an accident with a deer. Back in 2021 I vacuumed the system and refilled it using a robinair recovery machine at the vw dealership I was wrenching for at the time and the a/c worked fine. I believe the system calls for 20oz and I had recovered 17oz. Now that is getting hot in NJ, the a/c is acting up. The compressor clutch is short cycling, the FSM says low charge. I injected dye into the system, jumped the compressor and ran it then check with my UV light. Could not find any leaks, for arguments purpose, maybe it is low, I added 6 ounces of R134 to the system. Right now I don’t have access to an air con recovery machine so I can’t get an accurate reading on exactly how much refrigerant is in the system.
So I hooked up my a/c manifold gauges, with the engine running and the compressor clutch not engaged, I am seeing 38 psi on the low side and 40 psi on the high side. The clutch is still short cycling so I can’t get an accurate reading with the clutch engaged as it was engaging and disengaging every 5 or so seconds.
I bypassed/jumped the low pressure switch to get the clutch to stay engaged for long enough to get accurate readings. With the clutch engaged my low side is dropping all the way down to 5 psi and my high side is only reaching 125 psi, warm air is still blowing out the vents and the a/c lines aren’t getting hot or cold, electric fan never comes on either.
I’m a little stumped on what the issue is. I’m thinking either a clogged orifice tube or possibly a blockage in the system. The low side shouldn’t get that low. I’ve seen cars with weak compressors that are low on the high side pressure but still blow out cold air. The later 00-01 systems don’t have expansion valves so that rules out that being the issue.
Any ideas fellow Naxja folks?
