My lift kit is on the way, Should be here next week from rubicon, my question is, I have 2, 2000 XJ's to lift both are getting the same treatment, but in the mean time what prep work should i be doing to get the truck's getting them ready for "lift day" ie: spraying bolts? what spray? lossening bolts, also any tips or advise on the sye ,(hack and tap model) or even any advise on the over all install its a re6130 4.5 inch lift any help would be great
I read your profile and only found that you live in Nazareth. Not knowing which state that this is in, I can't advise as to how badly your bolts are rusted from snow melting compounds.
My Cherokee is a 97. It spent 1 year in New Jersey and the rest of the time in Georgia.
I just did my first lift ever just a few days ago. In preparation for the lift I sprayed all the bolts down good. My buddie, who is the mechanic between the two of us, told me I was wasting my time as all the bolts looked clean.
He got under the Jeep with a few wrenches and turned every screw that wouyld need to be unscrewed for the lift. He said there was not one problem. HE actually took out every shock bolt and then put anti-seize on each one and put them back in.
On install day. Every bolt came out easily. Didn't break one. He told me he wasn't surprised, but I was happily surprised. It seems that Southern Jeeps don't seem to have the problem that Northern Jeeps do. So depending where you live you may be just fine.
To make the installeasy and quick, you may want to adress the shock bolt issue by removing then reinstalling all of them. It should take under an hour if all goes well. If there is a problem, you have time to address it before "lift day"
Hope this helps-
Jeff-97XJ
