DeftwillP
- Round Rock TX
Can a thread be nominated?
Sent from tapatalk on iJunk
Are you saying that 5/8" isn't significantly bigger?The sheared 5/8" bolt on one of my 4-link uppers laughs at your single 10mm bolt up front.
youre missing the point entirely... nothing wrong with long arms at all..
no no, I'm just saying his basis for suggesting a 5/8" bolt as minimality sufficient had no supporting information. You're also jumping your XJ... So considering your application (use of the vehicle) it would suggest a 10mm bolt is not an option. I'm suggesting that IRO has not lost their morals for road safety by producing this kit.
I just think of 2 years of this is silly, don't you?
Now go out and wheel folks, life is way to short.
just because i like to play devils advocate, but whats your supporting information for thinking the single 10mm bolt is indeed enough? and what is the minimum size that should be used? when is a larger bolt required? after trial and error?
iFail
Sheer strength, b/c that's all I can provide. I do not have the means/time to assembly a fixture capable of measuring rotational force applied to the axle mount within this long arm system. I assume neither did they and that this bolt selection was a product of trial & error. I still think the forces applied to that bolt/link are different that those within a 4-link. It can only redirect load into the lower link.
s14unimog said:I also feel the hardware used for the top links in a 4-link are subject to different stresses. You're upper links transfer impact into your chassis mounts. IRO's third link can only direct that into the lower tube as it rises back to the cross member. Not to mention as your suspension travels through its range of motion, that stress on those upper links/hardware changes; correct?
:laugh2:Nope, just poking fun.Have a great day.By the way, i'm right and so are you, i think.LOL
- shear strength should not even be a part of this discussion. If it is, something has already gone wrong in the joint.
why not, that bolt is only in shear
- again, before I go dig up more numbers, what do you feel is a suitable design factor of safety for the strength of that single 10 mm bolt?
Who knows, I don't know what the peak forces are as applied in that application.
- links can only transmit force axially along their length.
which then transmits its load the the bolt in shear.
I'm sorry, I really don't understand this 'different stresses' idea. People have also had 10mm bolts fail when used in a trackbar application. It's different things that may cause the stress, but at the end of the day, it's the magnitude that matters, no?
they do. iron rock just doesnt offer it lol
Who makes it the army core of engineers?:worship:
I can guarantee you those bolts were not over-torqued.Also keep in mind when you over torque the bolt and just tighten the piss out of it, it greatly reduces the strength of the bolt with that being said those 2 applications that "broke" prolly tightened the Piss it out of it, and caused it to prematurely break...
(bold added above for emphasis)s14unimog said:At this point we're discussing whether the shear strength of a 10mm bolt is sufficient for the application. Some feel it is, some do not. There were real world figures provided and contradicting experiences provided.
NASA! KTM can't break space bolts!![]()
If you believe that a 10 mm bolt is strong enough for you, then buy the flippin kit and run it. Then real world experience will tell you if its strong enough or it isn't.
OK...we'll keep going with this.
