bert01xj
- souderton,pa
Long live this thread!
Ya know what fine. I give up, this is going no where. I don't work for IRO and have nothing to gain by defending their product. It seems this conversation is evolving into a more heated debate anyways. I appreciate the time you took to explain this to me. I've got the three link under my truck on 32's and have done mild off roading with it for a little more than 8 months now (I don't exactly live in Utah). As I continue to do wheeling trips I will observe it for myself under real world experiences. I originally spoke up in this thread to bring to light the problem I see with the loading capacity of the single upper bushing but that was over looked and I fell back into the topic that has kept this thread alive.
building a rig, wheelin a rig, and breaking a rig is what this hobby is all about. I'm sure I'll destroy many other components on my truck but this conversation has no end. Under the right circumstances any component will fail.
As many have requested, lets just let this thread die already.
btw, you have a badass XJ.
Y'all started the bit about bolt strength, not me. Sadly it seems that no one ever wants to continue down that road once numbers come into play though.![]()
probably bc you make our brains explode
Ktm you know I am just messing with you about breaking bolts right.
weiner-wagging.
And here I thought we were finally going to have a good conversation with *real* numbers and facts, instead of a bunch of circumstantial evidence and weiner-wagging.
I tried to drill out the stock one before and use a bigger bolt but couldn't do it with the rubber causing issues and the heat would melt the rubber.
Cutting oil dosnt help, the little nubs in the bushings cause the bit to jump and heat up the rubber and bit resulting in no progressdid you not use cutting oil? :nono:
its pretty easy...
1. you find the hole that you want to take a bigger bolt
2. find a drill and a drill bit of appropriate size
3. drill holes
4. install bolts.
whoever was having problems "melting" the bushings are you XXXXing high or retarded? you are supposed to use a drill bit, not a XXXXing torch. there is no way a drill bit can produce enough friction to melt those bushings, hell if that were so, the damn control arms would melt them just everyday driving the thing... :facepalm:
its pretty easy...
3. drill holes
4. install bolts
Uhh I was and I don't appreciate your "retarded or high" comments. That is uncalled for. You having a bad day or something??
Have you ever tried drilling out a stock sleeve that's encased by rubber?
