Spearfisher XJ
- SoCal/Maritime Academy
I have had a Currie 9 inch for well over 12 years now, and it has not hit the oil pan yet, and I have pushed the XJ pretty hard in those years. It's fine.
Thanks,
Fred
Explorer 1
I have 4.5" lift. Not too sure about up travel, but it flexes really good.How much lift are you running and how much upward travel do you have?
I'm adjusting the ACOS up from the "no lift" setting upward 1" and adding 1" of additional bump stops.
Thanks,
Fred
Explorer 1
question.... what is the giant hole in your frame rail for?
To the OP: Just some friendly advice, gusset the upper part of the inner C's and truss the housing either across the front or at least on the longside across the top.
I have the same housing that's 5 yrs old and it's bent up pretty good. I don't jump my junk or race through the desert, just from normal rockcrawling on 35/36" tires. I'm getting ready to pull it to have straightened and reinforced, but learn from my mistake and do it now.
Thanks for the tip......I picked these up today and will weld them in tomorrow.
Thanks,
Fred
Explorer 1
Thanks,
Fred
Explorer 1
LOL, I was just going to post a link but you obviously beat me to it. Those are exactly what I was talking about. Just easy insurance and simple to do.
I missed what tire size/wheeling you plan on doing so you might be fine W/O a truss but just wanted to point out my experience. I've had zero issues with gears or axle breakage though (I run a True HI 9 3rd and the Warn 30 spline outers) which was my reason for upgrading. After going to 35's I was snapping axles and stripping ring gear teeth on the D30.
Honestly I can see you're reasoning, but I think building a 9" with D30 outers is nutty.
I would say as far as the gussets heat and bend to where they fit.
I vote you notch the oil pan.
