yossarian19
- Grass Valley, CA
I don't want this thread to get cluttered with argument about HIDs or anything else. I'm trying to start a thread for polite discussion with metrics to back up assertions, or when opinions are given without metrics, a clear cue like "I think..." or "I feel...". Also note that I use Daniel Stern as a reference multiple times through this post and link back to his site. I am in no way affiliated with Daniel Stern and have never been a customer of his. He doesn't know I'm posting this, either. This isn't a commercial post. I hope it's informative.
The factory equipped headlights are #6054. The only info I could find, here, puts the lumens rating at ~700.
Daniel Stern, a well respected vehicle lighting consultant, recomends the GE Nighthawk as the only cost effective direct replacement. I have not tried these but am confident that Mr. Stern knows what he is talking about. Also note that these Nighthawk bulbs are rated by Mr. Stern a being a much better choice than Autopal H4 conversions, which I'll discuss more as we go.
The single most effective upgrade you can put on a halogen headlight system is a relay kit. You can find a description of this upgrade here.
Note that it is difficult to find quality parts for this upgrade in the appropriate wire gauge sizes and that Daniel Stern will sell you all the needed pieces for $49. I would recommend going that way.
There are also a variety of H4 bulb housings available that will swap in place of the sealed beam. These vary widely in quality. The $40 Autopal headlights I own are crappy. The best I can say is that they do indeed house an H4 bulb. The worst I can say is that pattern sucks and with my 100watt bulbs, I cracked both housings due to heat within a week of install.
Cibie, Bosch and Hella all make superior housings that would, I hope, stand up to high power bulbs. Any of those three will provide superior pattern and cutoff. You get what you pay for. Daniel Stern is glad to advise and can sell you what you want.
This chart has been illuminating (hah!) for me. Cheat sheet: A 60/55 H4 bulb will output 1000 lumens. A 130w/90w H4 bulb will output 1820 lumens on low beam, and melt or crack a cheap housing.
Other options?
Truck-Lite has an LED 5x7 module. When introduced, these cost $500 per pair. They are now down to $390. These have no replaceable parts but are very durable. It has a 50,000 hour bulb life. Low beam output is 1,300 lumens per side, high beam output is 2,600 per side. Since they are LEDs, the draw is under 7.5 amps for both sides on high beam. No wiring upgrades needed.
HID retro fits come in a wide range of price, color and quality. Lumens output is around 3200. Due to the wide range of quality and even safety with these upgrades, as well as Daniel Stern's blanket "no HID retrofits" stance (which is good enough for me), I'm not going to talk about them. I invite anyone with metrics & tech to contribute to do so.
For most of us, halogens are the way to go.
With Autopal lights which I don't recommend, a headlight harness and a moderately sized bulb, total around $100, you can substantially upgrade your lights. With a 70/65 bulb you'll have 4,000 lumens on high beam and 2,700 on low. Easily twice and probably three or four times the output of factory stuff.
For $250 + tax & shipping, you can get cibies + a harness + 130watt bulbs. This is cheaper and brighter than Truck Lites LED module.
Other options?
