- Columbus, In
Been running them for a month. no issues yet and they don't throw light everywhere like an HID in the same housing would. And Yes, there are better options. I know that but I can't afford them.
Let us discuss wire gauge. Here is a nice calculator to use: http://www.solar-wind.co.uk/cable-sizing-DC-cables.html .
IMO, wire sized greater than required is money wasted. A 100 Watt bulb will require 100A/14ADc = 7.14 Amps of continuous current, plus inrush.
Using the calculator, providing it with 14 volts, 7.1 Amps, a run length of one meter and specifying a 1% run loss factor gives a wire size of 14 AWG. At 5% loss, 21 AWG.
Why 14 volts? That is the actual operating voltage, not 12. Well, it is if the alternator is working properly...
I will say I am not impressed with my hella clear visions housings !
I have a harness and 80/100 watt hella bulbs seems to me the light is scattered.I have adjusted them I will try adjusting them alittle more to see if that helps. I like sharp cut off lines going to try the auto pal housings if my adjusting does nothing for me.
Junk.
From what I'm reading here, I plan on going with either these:
http://www.amazon.com/HELLA-0034272...1388092098&sr=1-7&keywords=hella+h4+headlight
or these:
http://www.ebay.com/itm/110881253343?_trksid=p2055120.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Autopals are half the price...not sure if the Hella's are worth double of them?
