This one![]()
Ok, what's rust again?I vaguely remember brown splotches on cars when I lived where that white stuff fell from the sky.... Weld through primer, then undercoat it when you're done. If you're really worried about rust the move to the desert, does wonders for stopping rust.
Always use weld thru primer before you weld on your stiffeners, you also do not need to grind the entire rail down to clean metal, clean the area's you will be welding too, two coat's of weld thru primer on both your frame and the stiffeners. Ten as said, undercoat the crap out of it when you are done.
considering how many holes in the frame and all why not just occasionally pour a quart of used engine oil into each frame tube. That maybe coupled with a good bead of silicone along the top and the front should slow down any rust. Just don't park in your nice clean driveway for a day or so.
I work at Sherwin Williams and we carrie some sort of Zinc coating that you can spray on metal buildings.. it weights 95lbs for 3.5 gallons and its a 2 part epoxy and a kit is like 70$ a gallon if I can remember right.
You need to use a Weldable Primer, get it at a bodyshop supply store. You can't even tell its there when you weld.
I once welded up an entire seat frame, was wondering why my welds looked so bad, then looked over and saw my gas needle at 0. Duh.
FWIW, the can does say "For weld-through applications." :dunno:
Billy
dude... $5 a can:
that probably adds up to more than the gallon strait up. How many oz are in that can? And I mean of the actual zinc compound, the weight on the can includes propellant and inert items.
Atmospheric corrosion getting started on the ground iron surface. This picks up mainly because you don't heat up the rotors if you let them sit for a while (the heat from use burns off the moisture - problem solved.)
Fortunately, the milder the alloy (going from high-strength tool steels down to mild cast irons,) the more resistant to rust they seem to be. That's still not as good as a decent corrosion resistant alloy (10-17% chromium content,) but it's good if the part isn't structural.
Thanks Jon, I actually knew why. I was asking the guy who said rust won't form if there's no standing water. :dunce:
