Darky
- 29 Palms, CA
Search, there's lots of people running the HD setup, tere's even a big thread about it.
MJ stiffeners would be interesting to see become available, but I doubt they would sell well.
The frame rails are totally different. from the crossmember back.
^^ I actually did this, Mark was very quick to reply!! I see some of these in my future very soon!!!
The only thing I with about with frame stiffeners is that if you stiffen one area it would only transfer the force to the next area, putting even more strain on the areas you can't stiffen... If that makes sense...
anyone running the H.D. offroad frame stiffener SET????? make a pretty big difference? think i might look into buying the whole set instead of making my own.thanks for the help.
There was a time I toyed with this years ago, the market is'nt there to support the investment, I tried..........sorry.
I’ve read were the use lockers would add stress to the framerails, but I’m having a hard time wrapping my brains around that idea. Any opinions there?
That right there.......is pretty silly......I often tell folks to "STOP READING".....seriously.
If you've cut, if you're wheeling it.......stiffeners should be considered sooner than later.
Honestly, our customer base is 2nd time builders, who've learned right & wrong.....
Since I have your attention, I've got a couple questions.
1. When I lifted my XJ, I wed a new rear spring pack to my existing main leaf in part because front leaf spring bolt on one side of the vehicle was seized up and would not budge. Lets assume that a future attempt would be futile even if heated and extensively PB blasted. Would I be able to effectively mount and use your stiffener without being able to move this bolt?
2. Correct me if I'm wrong, but your stiffener does not appear to go forward of the LCA mount. Doesn't leaving part of the framerail non-reinforced just make that non-reinforced portion more prone to stress/failure from flexing of the vehicle? IOW, isn't more of the stress transferred to the non-reinforced part of the rail?
Excuse me if these are naive questions.
Actually, exceptional questions......
(1).....That bolt is subject to some rust, it's also subject to flexing due to the unibody design which can break it's weld connections......this bolt does not need to be 100% removed to install the system, yet does need to be loosened.........
(2)......Forward of the LCAs?.......so, whats up there? A balcony of sorts? The system connects the unibody from suspension point to suspension point......actually 'connecting' the suspension points, which acts as a cradle to the unibody.......up front, whats behind has much less limited stress.....most of the front area has a triple wall from the factory in critical areas, the very rear.....not so much, yet tends to never fail......
A decent front bumper system will take up the slack 9 out of 10 times if you have serious front end concerns.........Our BackBone is a good example of that.
