Fishboy's Weight Weenie Thread
cracker
La Mierda
I am working on a Spidertrax 60/9" to replace the 44 on the front of my junk.
FileHandler.ashx
Got most of the parts to build the 60/9" I am working on.
This is what I have so far in my posession but I still have more parts to come.
FileHandler.ashx
I will be sending back the Tera Drive Flanges as I had ordered Warns and got these instead. My shafts are Alloy USA 35spline inner and outers. My center section is a True Hi 9 due to arrive tomorrow.
Paul has been hounding me to post weights of my parts. I finally had time to (waste) to do this for him.
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
FileHandler.ashx
Here are the totals in pounds.
Enjoy Paul :wave:
JeepFreak21 said:
How much do you have into it at this point?
Billy
Don't know...............don't really care.
David Taylor said:
Wow that's 20 pounds extra per side at least! That extra will keep you at the bottom of the Falls and on the strap. :smootch:
I'll take 40 pounds all day long as long as I don't have to deal with weak ass ball joints ;)
FWIW
I carry as spares for my front 44:
  • Spare pair of complete spicer shafts assemblies for both sides(inner shaft, u-joint, outer shaft)
  • Spare hub assembly
  • Spare inner and outer hub bearings
  • 4 Spare Warn premium hubs
  • 2 drive flanges
  • spare CTM
  • Spare 760-5
  • Spare Spindle with nut
  • Tie Rod
  • spare TRE
  • 2 spare Warn alloy stubs
With my current front 44 weighing in at apporx 330 lbs, all these spare must take my 'axle weight' over 500#. The Dana 60 will be lighter than my current axle with all my spare parts. :illegalflipoffsmilie:
I say embrace the pork.
If you know you are fat, accept that you are fat, and don't mind being fat, then you certainly don't mind carrying an extra case of BudLight on trail runs.
Then, when your stuck at the bottom of the falls, at least you won't be thirsty.
David Taylor said:
they are only weak if your junk is a pig. Fix that and you will find you don't need the king pins.
So your junk has been fixed?
After calling half of the industry, general consensus was ball joints are lastara when you have the option of kingpins.
Let us look at the Comp buggies which weigh 1000# lighter than your junk. They use ball joints and have to change them EVERY competition. Then they add 200# of water to add weight to their front ends. I'll take the 40# all day long.
I think I have to call it, Dave your full of shit :D
luvrox said:
No one in their rite mind uses ball joints anymore high end rig do they? :moon:
Birf expert Garry,
It seems as if Paul and Dave are really proud to build axles from scratch with ball joints.
Atleast Goat and Matt 'fell' onto their front axles (which had ball joints and they didn't have a choice).
When building an axle, no one with any common sense 'wants' ball joints when they have the option to avoid them.
cracker said:
Pete,
I guess you havn't talked to Ron. Looks like he will be on the ball joint band wagon as well.
cracker said:
Pete,
His name ain't Pete.
