right now , what they want to see in the comments are things like :
I prefer alternative 3, and also would prioritize the trails by putting Barret , strawberry, DV, at the top of the list.
You can also recomend changes to the alternatives as well, like
I prefer alternative 3 , but would like to see X Y Z from alternative 4 in there as well,
Also, they do not have to go back to court after this, once the supervisor decides on the final proposed alternative , they are free to move forward (they prefer number 3)
SO they still have to :
1. decide on preferred alternative
2. then conduct the proper analysis at each meadow to determine the best course of action to fix each meadow ( this will take time and be costly , requires environmental engineers to follow NEPA (national environmental policy act of 1972) guidelines and more)
3. actually get funding for the determined methods(applying for lots of grants and OHV funds - it could litterally take years to get funding through these grants)
4. get man power volunteered (in addition to forest service labor) from clubs that adopt the trails and from individuals that want to help out as well
The plan is to do it right this first time around, so we can be assured that we wont have trails closed over meadows in ELDO again, but that wont stop them from suing and closing trails over other reasons.... and that wont stop them from suing other national forests over the same issue.
I am not sure how to directly donate money to the FS, but I am sure we can contact them and figure out the best course of action - ( maybe it will be to donate to the clubs that adopted each trail? )
One great learning from this whole situation is to stay off meadows that are off trail, and to also be mindful when crossing through these things so that we do not further contribute to soil erosion that flows into meadows, diverting water away from meadows, and overall degradation of the vegetation.
here is a link to what some of the solutions may look like, you will have to search for meadow related content in here:
http://www.fhwa.dot.gov/environment...publications/fs_publications/00232839/toc.cfm
here is a table of contents for trail construction and maintenance from the federal highway administration:
http://www.fs.usda.gov/detail/eldorado/home/?cid=STELPRDB5362046
pdf of the supplemental impact study:
http://www.fs.usda.gov/Internet/FSE_DOCUMENTS/stelprdb5410354.pdf
alternative 1:
basically leave everything open and amend the LRMP
" Land and Resource Management Plan Amendment: Amending the Land and Resource Management Plan (LRMP) to allow continued public motorized use in sensitive meadow habitats will result in impacts to hydrology, natural vegetation and wildlife habitat."
alternative 2:
Alternative # 2: No Action- everything remains closed and no amendments to the LRMP- except for the 24 routes that dont cross meadows, they will remain open
ALternative 3: (preferred)
24 routes that dont cross meadows remain open, the 18 that do will remain closed until the meadow crossings meet the rules and guidelines in the LRMP
Alternative 4:
was developed in response to public comments received during the scoping period for this SEIS. There would not be any amendments to the ENF LRMP under this alternative.
Alternative 4 is similar to Alternative 1 except for the following:
The following routes or portions of routes would be designated for public motorized use: 09N54 (open up to intersection with 09N60, closed to public motorized use past that point), 10N06, 10N26, 11N09A, 11N22, 11N70, 13N24, 09N15, 10NY05 (open from 10NY04 to a point just before drainage near 16E27, and closed beyond that point) and 14N05 (open up to McKinstry Trailhead, closed to public motorized use beyond the trailhead), and 14N27.
17
Supplemental Environmental Impact Statement Eldorado National Forest Travel Management
The following routes or portions of routes that are currently closed by court order would continue to be a part of the NFTS but would not be designated for public motorized use and identified on a MVUM until the routes are in compliance with Standard and Guideline 100 as it pertains to meadows: 09N01, 09N08, 10N13 (open to a spot suitable for camping just north of Schneider Camp meadow, closed to public motorized use beyond that point), 10N14, 10N21 (16E27) (open except for the section between 10NY04E and the section currently open on the west end), 11N26F (16E21), 11NY32. This alternative identifies these routes for future corrective actions, but does not analyze the actions necessary to bring each route into compliance with Standard and Guideline 100. Corrective actions would be proposed and analyzed as part of future NEPA analyses, as funding to implement corrective actions becomes available. After corrective actions have been analyzed and implemented, the route would appear as a designated public motorized road or trail on the next revision of the MVUM.
The following routes or portions of routes that are currently closed by court order would continue to be a part of the NFTS but would not be designated for public motorized use and identified on a MVUM until mitigation for resource concerns not directly related to Standard and Guideline 100 and meadows is implemented: 08N23B, 12NY15, 08N35, 10N32, and 10NY06. The reasons mitigation is indicated for these routes are documented in the project record, but the mitigation is not analyzed in this document. Mitigation would be proposed and analyzed as part of future NEPA analyses, as funding to implement corrective actions becomes available. After the mitigation has been analyzed and implemented, the route would appear as a designated public motorized road or trail on the next revision of the MVUM. Portions of these routes that are currently open under the court order would remain open for public motorized use.
The following portions of routes that are not currently closed by court order would continue to be a part of the NFTS but would not be designated for public motorized use and identified on a MVUM until mitigation for resource concerns not directly related to Standard and Guideline 100 and meadows is implemented: western 2.26 miles of 09N04 (17E79), and 10N03.
The portions of the following routes that are currently closed to public motorized use under court order would remain closed to public motor vehicle use: 09N54 past intersection with 09N60, 10NY04, 17E12, 14N58, 17E17, 17E21, 09N82 (southern portion 16E26), 09N83 (19E01), 09N95, 10N01 (10N01B), 10N13 (17E73), closed beyond Schneider Camp), 10N21 (portion between 10NY04E and the section currently open on the west end), 10N98, 11N23F (16E33), a portion of 12NY06, 14N05 past McKinstry Trailhead, 14N39, 17E16, 17E19, 17E24 (west and east portions), and 17E28.
A portion of 12NY06 that is not currently closed to public motorized use by court order would be closed in this alternative.
what would be amazing, would be to get every 4x4 club in northern California to raise like 1000$+ each and all donate to the forest service, I would imagine there if there are 50 clubs we could take a real stab at it and raise 50K, which would definetly help a lot , but it would be a big start and it would greatly help keep all of these trails open. We could have like auctions of donated parts where the proceeds go to keeping the trails open, car washes, random stuff like that to raise money.
also I noticed that gold hills Posse is doing their first strawberry maintenance run In May, maybe we could help out with this and work on meadows then etc?
http://forum.posse4x4.org/calendar.php?view=event&calEid=135&sid=f87f1c2875ca96c1bd0072cabfba9750
The hi landers usually do their first maintenence and clean up run on Barret in August by checking their site, so maybe we can help coordinate something there as well.
and the south county trail riders adopted DV: but I cannot find anything on them other than this:
http://www.cal4wheel.com/north-district-clubs/item/south-county-trail-riders
maybe we could help aid in fixing up Deer valley.
Good news about deer valley, there is only one problem spot, that is the first meadow/crossing coming from the 4 side. the rest meet rules and guidelines. If we can get this one meadow up to snuff, we can get DV back open
and we shouldnt forget about the Pardoe trail (squar ridge) here is a list from another naxja thread last year on this issue
This list came from Friends of the Eldorado National Forest
Barrett Lake 4WD
Hi-Landers
Strawberry Creek 4WD
Gold Hills Posse
Deer Valley 4WD
South County Trail Riders
Squaw Ridge (Pardoe 4WD)
Mud Lake
Onion Valley
Porthole Gap 17E24
Motherload Rock Crawlers
Long Canyon 4WD
Sierra Treasure Hunters
Plummer Ridge (not affected)
Sacramento Jeepers
Hell Hole Trail (not affected)
Capitol City Mountain Goats
