Dan Fredrickson
- Sacramento, CA
3/8" Steel is just about enough ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thank you!just ordered a set and thanks for discount
The best is the Lube Locker gasket, they work better than anything and you don't need the RTV mess...Ordered mine tonight. 8.25 rear and D30 front, both with countersunk bolts and drain plugs.
Is a gasket better than silicone for these covers?
One box so shipping is less...when you order two do you ship them in separate boxes or one
Give us a yell in the morning...Sounds like someone over here screwed up!well then im missing a diff cover
I thought I was the only one he told about thatX2 on the Lube locker gasket, mine has been off 10+ times, still works great.
Dan, when will you guys have Scotty drop by? I would dig some transparent aluminum diff covers.
We don't sell the gaskets. We just cannot figure out a safe way to ship them without destroying them...Just ordered mine for the Dana 30, hoping it will stiffen up the housing a bit since I just destroyed a ring and pinion from housing deflection. It's also going to make a great spot to mount a ram for hydro assist steering in the future.
Just saw the comments on the Lube Locker Gasket, is that something I can purchase from you as well?
