Well, since I was held up from leaving to go to the Rubicon on Thursday Morning because of a hole, I got it done in time to head up there for Friday. But as it goes another h... held me up.
(she laughed too!) My wife wanted to do something else. So instead we drove the XJ up to Pismo Beach on Friday to 'freeway' test the Jeep. It seemed to be fine. I know I am at about 3 degrees of castor but it seemed pretty good. I actually have a lifted Ford Expedition that drives as if it is on crack (I sneeze and it goes left) so I am pretty used to a twitchy steering but as you can see my pinion could be dropped a tad. I will do that when I pull the 3/4" coil spacer out in a few weeks (before Swamp Lake).
Pismo was a success. My wife and I drove around the dunes for a little while (it was my first time in the sand like that.) It was pretty fun. That was the 'dune' test of the new D44.
This one is as we are leaving. This is the XJ fully loaded for wheeling. I am still a little concerned about being that high but so far no significant issues (yet).
I took it out today to Rohwer Flats to test it out and I have to admit (I know it is an easy trail) but the trail was even easier than usual with the 44 and 35s.
So far so good. The only MAJOR thing I learned is that I need to change to a shorter (stock) pitman arm. I actually met a fellow XJ'r after the run and picked up a stock pitman arm. When I install it I will lower my hole on the track bar mount and cut off the excess (trackbar tower) above it (and finally paint the thing).
Actually I do have the coil pad back a tad. Only on left turns does my right high-steer arm hits my swaybar mount. I am going to address this later this week and should have it corrected so my tires then will hit my long LCA.
You have to ask Mike for the 7 1/4" arms or his regular arms will be way to short. The 7 1/4" arms are still 3/8" shorther than the stock knuckles are.
MINE (passenger side):
STOCK (drivers side/coil pads are way forward) :
I actually do think I need the stabilizer. It is a daily driver and my wife drives it too. I will have it set up differently later this week when I get the new pitman arm installed and I will be able to tuck it (stabilizer) away pretty well.
YOU HAVE NO IDEA HOW GOOD IT FEELS TO HAVE IT BACK ON THE ROAD! I was pretty stressed and tired from busting my ass for 4 days getting it all set up. I had to borrow a car from a friend to get to and from work.
Goat, do you have any concerns as far as my height? It seemed fine off road and I know you sit up there pretty high too (even with 37s). I understand
height=easier rollover. I would like to get a different set of rear leafs to set me down a tad but as you can see in the beach pic above, it levels out when loaded up (plus I am removing the 3/4" coil spacer).
-Avery
