Jump This
Just another minion!
- Borrego Springs Ca.
Rawbrown said:Rick, did you just weld that plate on top of the sheet metal or did you expose the frame rail. Cuz that sheet metal is only spot welded to the frame rail. for mine, I had to remove the sheet metal and get to the clean flat frame rail. the sheet metal on top was all un-pretty. cut off wheel, body saw and an air chisel got it out. To bad its all gonna come back out again. I just don't feel like working with the frame rails.
Its welded to the plate. I couldn't see any advantage to taking it down to the frame rail. God knows there isn't much metal there anyway! The plate I added is broad enough to be able to either bolt or weld additional support for the hangers. Although my bigger concern is cracking the damn thin factory plate. I was thinking that using doublers without welding would have been a better idea......too late now!
So, if your not going to work with the factory rails, are you going to link it or just plain ol' build new rails?
Rick
BTW you are just to take a look at the ring and pinion mesh on that 30, its one of Cal's old ones and ...well....you know Cal.
