jeeperjohn
- Temecula, CA
Considering what you're running, I would go with 60's.
Did you see this question Goatman? What are your thoughts???
That should be a full float D60, which is 30 spline.....same as a D44. Any full float (stock) D60 has to have the spindle bore size increased so you can put in 35 spline shafts, unless you get one of the more rare models and years that already has spindles that are large enough to accept the 35 spline shafts.
Not exactly 'rare', just have to know what you are looking for.Any full float (stock) D60 has to have the spindle bore size increased so you can put in 35 spline shafts, unless you get one of the more rare models and years that already has spindles that are large enough to accept the 35 spline shafts.
The way the op wheels either a 44 front with rcvs or a 60 front....... and I am a huge fan of the 14bolt, shaved of coarse.
Juna67 kit
I think that would be the Jana76...?
