klonestar
- White Mtns. New Hampshire
SBrad001 said:The only way you might get some positive increase in performance from a dual exhaust system with an inline six, would be to have a header with two seperate collectors that ran down to individual exhaust lines with some kind of crossover.
But dual exhausts off a single split would only garner you a lot of weird stares from most people. It might look cool, but you wouldn't get any increase in performance to speak of.
Depending on what rpm range you want to run you motor at, it would just be better to just increase your exhuast pipe diameter. Anything larger than 2.5" would be pointless, unless you planned on consitantly running greater than 5000 rpm. If you still want your low-end torque, 2.25"(stock) is plenty.
Thanks! Makes sense to me. Plus seems like more underneath to get banged up. Just wanted to check in case I was missing something.
Ken
