BRIANHO13
<- Yum Chocolate
- Spring, TX
Need to order some rubber bullets.
Do they make those in .45? I won't leave it in the truck this time!
Well, my new year's resolution is to get everything I've bought for the heep actually installed on the heep before July 4th.
1. Front, mid and rear stiffeners (will trade spare bedroom 30 minutes from the ocean for install *Doug* )
2. Front air bumps
3. Artec high steer arms and double shear brackets
4. Fab drag link and tie rod for new arms
5. D300 install with twin sticks
6. Rear bumper w/tire carrier fab and install
7. C-pillar cage fab
8. Tube rocker replacement
9. Cage feet install with rocker/frame reinforcement
10. Rear axle truss install
11. Slip/twist traction bar install
12. Front CTM rebuild
13. Rebuild long arm joints
14. Rebuild front/rear driveshafts
15. Replace rear D60 pinion seal/nut
16. Finish led rock lights
17. Install lower radiator hose w/spring and solve highway overheating problem
18. Refinish front bumper and light mounts
19. Design/fabricate/install harnesses for the kids in the bench seat
20. Install cage padding
I'm sure there's something else in the garage I'm forgetting, but that is a pretty good start.
I hope this is all done the week before the crawl...
mac 'or i'll be helping wrench ' gyvr
I'm allowed to work on it but I'm not allowed to wheel with you?
Install my new rear bumper with swingout tire carrier.
Done! Also fixed the passenger side door lock and installed a mirror. YES!
Mark did most of the work. I'm just the tool flunky, gofer, etc.
It looks like Floyd the Struggle Wagon is going under the knife again very soon. Just ordered some stuff for a double triangulated four link in the rear.
Maybe a full tilt big boy stroker if my money tree keeps producing.
I have a 4.7 stroker that's needs a little work (cam needs replaced but I have a cam kit from 505 performance to go with it) that I'm not using. I can bring it to the crawl. With my 5.9 I don't have a use for it anymore.
my wife is in the market.....how much?
