DrMoab
- The Utah Backwater
Well here is a starting list.
Finish engine that's in my garage and swap.
Rebuild transfer case
Install new AC dryer (AC freezes up in dry Utah air, can't imagine what humidity will do.
Pull rear axle and try to figure out why oil seeps from the plug welds, install new ubolt eliminators and new shock mounts.
Cut and rotate one front knuckle back 1.5 degrees.
Fab up and install new WJ steering.
Try and fix the rust around the windshield so it won't leak when it rains.
Go through both driveshafts. Make sure they are up to 3600 mi of rotations.
Have spare driveshaft built.
Fix stripped out holes in the frame so the belly pan (and front axle) doesn't fall out.
