camarors8992
- Liverpool, New York
That's what she said...
Worse advice ever when trying to put HID in an H4 housing. The clear housings have a notoriously poor beam pattern even with a Halogen bulb.
Yes, the clear housings and HIDs are a bad mix!
Ok, so to recap:
Can someone post up the recipe for the best *ahem* affordable HID?
e-code autopals + urban yan's converter thingamajig + FlexdXJ's cheap kid = win?
Dammit! Ah well, whats another 40 bucks! I accidentally ordered the clear ones. Hopefully i can return them if not i can sell them.
Yeah, if you ordered on ebay from Riminic, he is great to work with, I would ship back in return for the e code housings.
I think my suggestion is best if you have plans to eventually do a proper projector retro. A proper retro requires: 1) affordable headlights you're willing to carve 2) an oem d2s take-out kit 3) bi-xenon projectors 4) harness. By purchasing a cheap D2S/H4 shield you should have a clean cut-off, and most importantly 2 of the 4 components to retrofit projectors already in your truck (remember - aftermarket HIDs don't work with OEM projectors).Ok, so to recap:
e-code autopals + urban yan's converter thingamajig + FlexdXJ's cheap kit = win?
The problem there is that you need clear lenses and I haven't seen a quality clear lens housing worth the effort to actually do the retrofit on for our lights.1) affordable headlights you're willing to carve
Bajahid sells bixenon H4 kits that pivots the bulb. I've been tempted to try them in my Cibies, which are probably the best halogen H4 housing. I'm just concerned that if I do the kit I will have too much glare and just take them out. That and I don't know how long the pivot mechanism would last.The problem with my idea is that - until you do the projector retro - you'll be stuck without a high-beam, so if you're not interested in doing an eventual retro than you might as well buy an aftermarket H4 hi/lo kit, and cross your fingers you didn't buy a dud.
Most lenses suck. Even the ones on my pricey bi-xenons aren't that great. All you really need is a 6054 with a clear lens; the actual headlight housing/ reflector quality doesn't matter since all the light output will be managed by the projector itself. Even if you were to buy a headlight with a crappy lens that discolored or broke after the retro replacing it with a new lens would be fairly straight forward. All the real work on these retros is in the housing, headlight buckets mod, and wiringThe problem there is that you need clear lenses and I haven't seen a quality clear lens housing worth the effort to actually do the retrofit on for our lights.
Would this be the case if you were using the Retrofit projectors? I was told you need the 6054 with the patterned lens for HID's like the ones from DDM or BajaHID. I am hearing what i think are conflicting arguments about this. I'm confused.
It generally doesn't matter what type of lens you use with projectors... HIDPlanet is proof of this.
Without projectors? I'm honestly not sure, but I suspect you're right about the patterned lens.
Sylvania used to make a DOT approved HID kit for our 6054 application back in the day. It didn't
use projectors, and it had a patterned lens. Here's a pic.
