blistovmhz
- Vancouver, BC
98XJ, 5.3L, 4l65e, hybrid 231c/j and 241c, d30/44 4.56 lunchboxed, on 35x12.5r15. Roughly 5000lbs loaded with trail supplies.
I dunno if I'm just insanely lucky, ridiculously good at not destroying stuff, or everyone is crazy, but I've had very few axle problems thus far, despite being the guy everyone laughs at as I fly past them on a climb, cause "he'll be the guy blocking the trail ahead with a busted axle". Somehow though, despite the v8, 35's, extreme abuse, I've managed to blow one u-joint (before the v8 swap, and it was probably a stock, original joint), and gone through a few sets of uni's over the past 5-6 years.
I never planned to do tonnes, but for a bunch of reasons I'm now considering it:
* Primary issue is Uni's. I'm blowing through a set once a year, which isn't a huge deal, but I'd hate to have one totally fail on the trail. Hasn't happened yet, but I like my stuff to be relatively low maintenance, and uni's have become a maintenance item.
* Currently running 35's, but they're too easy to spin. I feel like I'd actually save money by going to 37's, just from a tread life standpoint. But, 35's really feel like the limit for my built 30.
* Bigger brakes. The WJ akebono calipers and rotors are much better than the stock D30 XJ stuff, but I'd like more.
* Rear 44 needs some work, and I figure if I'm breaking something, it's time to upgrade and go bigger. I keep bending caliper mounts (KJ), and either way, I haven't been able to make the KJ discs come anywhere near competing with the WJ fronts. I figure throwing in a 14 bolt would be a simple swap, but if I do it, I'd wanna upgrade the front to match.
So anyhow, I keep coming back to a shaved 14 bolt rear, cause it's easy and bomb proof. If I do a 14b rear, I really need to get to work on the front axle as well, but the D60 just seems massively overkill. 500lbs of metal vs the D30's 240lbs seems like more of a leap than I really need. Besides which, the 60 is a PITA to setup for a daily driven XJ. I'm comfortable with fabbing bracketry, and maybe even shortening the pass. side, but damn that mass. Is there really no good middle option for a daily driven, but extremely off-road beaten XJ?
I also don't necessarily want to go to 17" wheels, but with the Ford 60's massive caliper and rotor, you really need a lot of offset to fit 15's, or you have to go with 17's. If I go 17, 37" rubber is WAY more expensive than 37x15.
Also, given my only REAL concern with the d30 at this point, is the uni's, is there anyone making a stronger uni? No, I don't want to spend $1500 on converting to 44 knuckles. Again, for that much money and time, I might as well be half way into a 60.
Edit* Has anyone got any experience with AlloyUSA's 30 spline unit bearing? - http://www.alloyusa.com/alloy-usa-12168.html
I've had only good experiences with their stuff thus far. Would be awesome to be able to just upgrade the unit bearings and call it a day.
