NAXJA is having its 19th annual March Membership Drive!!! Everyone who joins or renews during March will be entered into a drawing! More Information -
Join/Renew
I lost your phone # so I could not call. What have you heard about a 9 inch currie front end. I talked to currie, but they sell them so I need some unbiased info. I would appreciate any help.
Basically, a high pinion nine inch front is the same strength as a HP44, with the possible advantage of pinion strength.
Shafts are 31 spline, so they will have to be custom units. Joints will be 297/760 size (same as a 44). The sheet metal housings are nice because you can weld directly to them without fear of breaking the casting, llike on a 44.
Air Lockers for a 9 inch are leakage prone, but are strong.
