bmikes
- portland or
99 XJ DD & Weekend Warrior
Fab it!! Make that bad boy beefy!!
Well, I'm putting it together at least....IT'll be plenty beefy, 1.25" DOM with 1/4" wall.Fab it!! Make that bad boy beefy!!
I'm talking about the straight reamer, to ream the inside of the tube to the proper max diameter of the thread.I told you I had the reamer. And you could have had the ends drilled and tapped for 50.00
Go to Tacoma screw and get the jamb nuts I've got them there and if they are not on they shelf they can get them pretty quick and ask for jamb nuts and they will get you the thinner nuts for it
Sounds like you got the jamb nuts sourced, but for future reference try R&P 4WD in, Oregon City. When I was doing some research on building an inverted-t steering system R&P had everything I needed at the time. Including machining for steering links as well. Plus they're a cool locally owned 4x4 shop. :thumbup:
Did you think of or try Parkrose Hardware? The one on Sandy Blvd has to have to biggest selection of nuts & bolts ever. Check it out.Thanks for that, I cant believe I didnt think of them before.
MSC, McMaster-Carr, and Fastenall were all a bust....unfortunately, so was Tacoma Screw.
They don't stock the 7/8"-18 jamb nuts, but COULD do a special order, IF I was willing to order the minimums from their vendor.
And since I have no need for 9 extra LH AND RH jam nuts of this size.... I have no other option than to go with the ONE online vendor I found that actually has these.
Order has just been placed with Ruff Stuff.....
I found them over at Ballistic, but for $2 more per nut....(no thanks)
I should have these next week at the latest.
Now all I have to do is source a Durango box....
I COULD go scavenge the junk yards, but I'd almost rather get a new or at least a reman one for peace of mind sake.
Problem is, even thru rockauto.com its over $200 w/a core. Local parts stores aren't any better.
Anyone have/know of a source?
Wow! Thanks for the write up. I just ordered (early this week) a 3.5" Rubicon short arm lift kit with full leafs and shocks from 4WD.com and it should be here tomorrow. I'm only on page 3 of your thread but it is perfect timing to come across this. All good info for a first lift. Not sure if I am going to do it or have John & Jason at Auburn Car Repair in Auburn, WA. do it for me. But if I do it you can bet I will be re-reading your posts.
Can't wait to get my '90 XJ's lift on!arty:
