Premature U-joint Failure - Jan_2013
Taking the off-ramp on my way to work the other morning...I hear this *CLUNK*CLUNK*CLUNK*CLUNK*CLUNK*CLUNK......
Pull into the gas station right there and found THIS:
Limped it the extra mile into work, and had to figure out how i was gonna fix it....
(I JUST REPLACED these like SIX FRICKIN MONTHS AGO!)
After running and getting a couple new U-joints, (thanks to a ride from a fellow Jeeper) ....I tried to opt for a quick fix and replace JUST the missing cap and snap ring, as the rest of the joint looked just fine.
Once I did though, I saw the reason that the previous cap had ejected itself.
(note the gap on the left side)
Apparently the yoke on the short shaft side had one of the ears stretched out. Honestly it was probably like this for a while, but slowly getting worse and worse since that one night up at my friend Bens house and the 20 tons of press force it took to get the old OEM joint out back in April/May.
We (crazymoose & I) ended up heading out to 205 Auto Salvage
http://www.205autosalvage.com/
where I have gone several times for JY Jeep parts. They have the largest inventory of XJ's anywhere in my area. Ended up running into Ryan R. from Bri & Bub Offroad down there...funny seeing another Jeeper I know out of the blue at the JY like that.
Cori has taken good care of me there in the past because I've sent her so much business over the years. This time was no exception. I ended up pulling out a whole PS shaft assembly (outer/bearing/joint/inner) and got it for a great discounted price. Even got a free T-shirt out of the whole deal!
Came back to work, and opted to install the whole JY assembly instead of wasting the time (right now) rebuilding it all. - I'll do that at home this weekend.
The drive home proved that the JY parts were good enough to commute on, at least for the rest of the week. I really have no intentions of testing their integrity on the trail....so the rebuild will happen sooner than later. I'll keep the old parts as emergency trail spares.
I want to make sure that Jason (crazymoose) gets a HUGE THANK YOU for coming out and helping. Although his bruised leg prevented him from doing much wrench turning (its a one man job really anyways) ...his arrival with jack, stands, and a few of the larger sockets I didn't have with me, plus the ride to & from the JY, proved to be the difference between getting this job done, and the Jeep sitting for gawd knows how long here at my work.... So thanks again brother.... I owe you one!
So the following weekend I did the rebuild, it was a good thing too, because by the time the end of the week rolled around, that donor JY axle assembly was making some serious noise.
So that Friday Night, I tore into it. Pulled the tire, removed the caliper, the hub nut, the rotor and unit bearing, and pulled the junk yard assembly out to tear it down. Now that that was out I could work on the tear down of my old axle assembly. The hub nut was the first thing that needed to come off...this is where the first problem arose.....
Not having the drive train of the vehicle to give me leverage, I had to turn to my biggest pry-bar to give me something to wrench against....It didnt make it.
I did manage to get the hub nut off though, and I was able to finish the tear down of the old axle using my trusty Harbor Freight press tool.
All in all, it was in pretty good shape, I did find one broken needle bearing though inside one of the caps.
The JY axle U-joints didnt come out as easy, again I was in a position where I was running out of torque. I didnt have a vice, so I was doing all this with my press tool on the floor. I called up a few local Jeepers and my buddy Brandon came thru. "Yea man, c'mon over-you can use my vice!" I brought the donor axle over and tore it down with ease using my press tool in his vice. I cleaned it up and pressed in the new joints with ease.
Finished assembly ready to go in:
Remember when I said that JY axle assembly was making some noise there at the end?...yea.....here's why:
Two of the caps lost their needle bearings. And were rusted into the axle well enough that they stayed put, but the U-joint itself was bouncing around inside the caps....GOOD TIMES!
The new assembly went in and I buttoned everything back up.
All ready for the road and trail now!:
When I was putting everything back together, I noticed something strange about my PS bump-stop.....it was hanging at a weird angle.
Upon further inspection I saw that it was basically destroyed.
I pulled it out in a powdery, crumbly mess. It was stock, and 220k+ miles old anyways, so I'm not too surprised really. But I'm gonna have to take of this pretty soon. (stay tuned!)
