Lower Track Bar Bushing Replacement _ Feb 2013
The replacement lower track bar bushing came in yesterday, picked it up from 4wheel parts (because rugged ridge doesnt sell to the public.)
Took it home and got to work on the swap.
Pressed/pryed out the old....and compared it to the new:
The old bushings apparently got worn pretty quick, turned a little soft, and one edge got eaten away a bit.
Also the metal sleeve in the center had ovaled out, and the clearance hole for it in both halves was wallowed out as well.
With the old bushings out, I removed the rest of the track bar, and took it over to the vice to begin the installation.
The bushings were greased and pressed in: (sorry for the lack of focus here - but you get the point)
I wasnt about to install this new hardware into a mount with a wallowed out hole.
And since the old metal sleeve was so ovaled out, I couldn't use the larger hardware I had shoved in there on the new bushing/sleeve set-up.
With the smaller hardware in the mount it was like throwing a hot dog down a hallway....
SO I opted to do what I have seen done on other builds and re-enforce the front of the mount with a metal plate and a freshly drilled (smaller) hole.
I dont have stock piles of metal plate laying around, so I had to use some ol' fashioned ingenuity...
The cut up OEM control arm I had laying around would serve well enough to give me just enough metal to accomplish what I needed.
It was placed in the vice, and using my grinder with a cut-off wheel I removed the donor metal....
I then hammered, and clamped it straight, Viced it up one more time and drilled the new clearance hole:
(again, sorry for the lack of focus)
I then wire wheeled it clean, and trimmed it to its final shape.
Using the mounting hardware for the track bar I clamped it in place
.....and did my best impersonation of someone who knows how to weld.
Satisfied with my ability to grotesquely tack two pieces of metal together, I spray painted it for protection, and called it "good enough."
I know its ugly as sin, but that metal ain't goin' nowhere.....
It'll more than likely all end up getting cut off eventually anyways for when I do a steering upgrade,
and have to modify the track bar, and mount it higher up on the axle.
The road test the next morning proved to be a much better ride than in recent past.
MOST of the wobble is gone, but I can still feel the degradation of the TRE's....they're next on the list.
