Big Red
- Roscoe, IL 61073
HTeK said:IMHO, the cheapest most effective and "fairly" reliable way to run 35's is to:
1) Get an XJ 44 or an 8.8. It aint that expensive. $400 AT THE MOST... could be done for under $200 if you're resourceful (unfortunatly you didnt do that BEFORE you got gears :doh: ... so tack on new gears to the price)
2) Swap 760x shafts/u-joints into your dana 30.
3) Make sure you adjust your steering stops to avoid u-joint binding
4) Run it... As long as your not a throttle jockey you should see minimal breakage.
-jm
Good points jm. How do you adj the steering stops? Be easy on it is 1 of the best things, lockers are nice because you will feel less of a need to throttle it, but also contribute to breakage due to the added stress.
Troy
