- Rainy side of Washington
Check the input shaft (all 2-3 of them) diameters and lengths and spline counts, wouldn't want to screw that up only to discover it won't work upon starting. Also check the transmission fluid pump gear pattern - it's two notches cut into the neck of the torque converter on a Jeep AW4 which mesh with the pump gear, I'm not sure what it is on an A340.
