@Adrian: WTF is that instrument cluster from, I want it.
Someone on jeepforum suggested I make a list, now that I'm near the end. LOFL.
Here is the final list:
1. 02 sensors wired in
2. Oil pan bolts installed
3. Boost controller connected
4. Starter wire insulated
5. Crank bolt torqued
6. Crankcase ventilation filters installed
7. Engine oil filled
8. Coolant (water) system filled (water will be replaced by 50/50 after break-in)
9. Trans oil filled
10. Power steering oil filled
I have a few other things on the list, but they will be done after initial startup is behind me...like building the down-pipe, installing the driveshafts, fixing the rust hole in my floor pan, etc...
So at 3 am I thought I had a short, but I realized today that my dumb-ass had the key in the ignition in the "run" position so I could steer it when we pushed her in the shop. Embarrassing, yet relieving.
As far as heat management goes, I will be keeping a close eye on EVERYTHING for weeks to come, I assure you.
School has started now, and I guarantee that Chem and Calc III will be vying for a lot of my time, but this week I'm gonna take it slow, relax, breathe, and finish these last few things right. Rushing is how we XXXX up. With maturity and experience comes self-control... supposedly.
Either way I'm not rushing cause I don't want to make a mistake. Chances are several have already been made. That being said, this Jeep will be running by Sunday.
