USMCGunrock
- NJ/NY
Wow! 3hrs reading this thread and its all worth it!! One heck of a build..can't wait to see it up and running. 4wd burnout with ur current setup?....ur wheels will run without ur truck..hehehehehe
I absolutely plan on getting video of this Jeep doing a 4-wheel burnout... but not until the front bumper situation is addressed, lol. I may or may not need to upgrade all the Jeep drivetrain components too. Dana 30 and 35 with stock NP231, we'll see. I expect everything to last longer because of the way the power will come on. Nice and smooth, no jarring. Then again some part might just crumble. The Supra wheels will put a LOT more rubber on the earth, so that may break something too. I still have to do the wiring and plumb all the hoses/lines, like coolant, fuel, oil, etc...
Sunday's list includes:
1. Waste gate solution (actuator modification)
2. Compressor housing (Compressor outlet connection and waste gate bracket fab
mounting)
3. Dash/center console removed (help with wiring access, install boost gauge, and try to move
transmission shift cable to passenger side.
4. Complete inventory of parts ready to be coated including black powder on the
compressor housing, intake and charge piping. Black ceramic coating on the
manifold and exhaust housing.
I doubt I'll get to it all, but today was out of the question.
Yeah, in case it wasn't clear, the 4wd burnout will not happen until the axles and tcase are upgraded.
I am working right now. Everything on the list above is done, except for number 3. Dash is out, and right now I am working on removing the blower and ducting, as well as the center console. T-handle on the shifter seems a bit tricky. I'll still have all the fluid hoses to terminate and connect, and the cables (throttle, cruise) look like they are going to require some thought. I'm hoping to be able to either relocate whatever part of the a/c is directly inside behind the bulkhead or put some 90 degree fittings on it so the lines are not interfering with the manifold. I expect to be prepped for wiring by COB today.
Pictures and videos will be up later today as well.
Once on the dyno, you are not likely to damage anything as everything is turning. I agree that it and you will need some run in time to adjust for the extra oomph. Keep in mind that the power really doesn't get applied until you are in 3rd gear on the AW4, 4th on a 5 speed.
So you have proven, once again, the 7P theory of Project Management.
Proper
Prior
Planning
Prevents
Piss
Poor
Performance
