Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
Old November 21st, 2006, 19:09
David Taylor's Avatar
David Taylor David Taylor is offline
NAXJA Member #570
Jv carnage list
So what did everbody bend, bust or dent ?
My drag link will need to be replaced.
Went to pull it off the trailer and found this.
Another broken wheel. same thing as last year. This event has my nunber
on wheels. Here's a shot of last years.
Old November 21st, 2006, 19:20
Kevin3151 Kevin3151 is offline
Re: Jv carnage list
Nice,
Amazingly enough I only dented in my transfer case skid a bit and dented in my drivers side doors a touch.
Overall I'm happy. The last time I was out there, it was a lot worse.
KH
Jes's Avatar
Jes Jes is offline
www.urfracing.com
Re: Jv carnage list
I cut a tire and my rear locker stopped working. Won't know what's wrong with the locker untill I pull everything apart.
Old November 21st, 2006, 19:23
Matt S. Matt S. is offline
Re: Jv carnage list
My damage consists of
1 bad steering box (going to rebuild and tap for hydro assist)
1 f'd up track bar and mount (going to build a new one and fab up a new mount when it goes under the knife)
Cracked frame around the JKS SBS system (this is going to be hard to fix. going to wheel it one more time then lop the front of the body off for tube)
Front header panel ripped off (opps)
dana 30 has no more seals in it (going to build a whole new housing and polish the 30)
Other than that damage, plans are now to tube the front out, inboard the rear springs, tube more of the rear, and tube more of the middle.
Old November 21st, 2006, 19:26
Ben H's Avatar
Ben H Ben H is offline
Re: Jv carnage list
Driveshaft
rear yoke
fan through radiator
tail light
rear quarter panel
wedding ring
Old November 21st, 2006, 19:28
NAXJA Member #570
Re: Jv carnage list
Sorry about that. I should have gone with my first thought of just driving up the tire
and over the fender.
Old November 21st, 2006, 19:34
Re: Jv carnage list
Now THAT would have been cool AND funny!
Old November 21st, 2006, 19:50
Goatman's Avatar
Goatman Goatman is offline
Re: Jv carnage list
I wasted a front u-joint, then later ripped out the front u-joint u-bolts. I also broke the front track bar in half on Resolution on Sunday. The front suspension that came with the rig, and I didn't change, has to go. It was only going to run this trip, and now that's for sure.
TEAM/PETTY CASHRacing........2013 Ultra4 Stock Class National Champions
Check out the TEAM Facebook page for the full story of our 2013 winning season: https://www.facebook.com/Team
Thanks to , Falken Tires, Bishop-Buehl Racing Engines, Ten Factory Axles, Brown Dog, Hooker Harness, BILSTEIN, Raceline Wheels, WARN, G&G Auto Repair/Off Road, Yukon Gear and Axle, Full Traction, Cal, Russ, James, and many, many others.
Old November 21st, 2006, 20:09
Jeepsterboy101 Jeepsterboy101 is offline
Re: Jv carnage list
Trackbar mount
Old November 21st, 2006, 20:38
Rawbrown's Avatar
Rawbrown Rawbrown is offline
Re: Jv carnage list
THe new PSC box worked so well that it cracked the frame in a different spot in between the box and TB bracket. also cracked frame around TB bracket... Also cracked frame just behind the stock passenger side LCA bracket. All 4 leaf spring to body mounts are bending and distorting metal. This means that the leafs gotta go. the front has to be completly redone and the front suspension has to be converted to Long arm.
as for the body. its looking like it needs alot of elbow grease to buff out the scratches. the "D" pillars are about done having no rear hatch allowed to much body flex which fatigued the top of the d pillars. crack, crack....
halfway through aftershock on sunday I found the crack/crunch noise of a cracked frame rail kept getting worse and worse on the tougher obstacles. I turned around and hauled axle back to camp. So what are my plans? lots of cutting, bending and welding. And I'll leave it at that.
Old November 21st, 2006, 20:45
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: Jv carnage list
Originally Posted by Ben H
wedding ring
Doh. That sucks.
Old November 21st, 2006, 20:58
Goatman's Avatar
Re: Jv carnage list
Oh, I forgot, I also badly bent my tie rod.
The funky Tera long arm setup is going bye bye, and so is the steering setup.
Old November 21st, 2006, 21:02
cracker's Avatar
cracker cracker is offline
Re: Jv carnage list
Bender Alley ate me up a tad:
My PSC box started leaking real bad (but not anywhere near as bad as Santa's) on Friday so I swapped it out for a stocker and then on Sat I broke a(nother) 44 hub.
I am so looking forward to full hydro and a 609
Old November 21st, 2006, 21:11
XJ_ranger's Avatar
XJ_ranger XJ_ranger is offline
Talking Re: Jv carnage list
bent my high clearance tie rod into an even higher clearance tie rod...
ran outta washer fluid...
lost a bead, ripped a valve stem, bent 2 rims...
my doors dont close all the way anymore courtsey of my self boatsiding cut out rockers...
I somehow loost / sheared a t-case skidplate bolt, and welded it to the frame to make up for it...
broke the castor asjuster - but not the side i welded - the other side...
Nothing in Moderation . . .. . . . .... . . . . . . . . . . . . . . competitor #91 . . . . . . . . . . . . . . . . . . . . The Ride Racing
Originally Posted by Bryan C. View Post
As if the program is running with some high level of integrity and only the best of the best win.
Old November 21st, 2006, 21:18
FarmerMatt FarmerMatt is offline
Re: Jv carnage list
I thought I heard a crunch while taking it for a spin...
I ripped my steering gear off the frame rail. The back bolt hole cracked, the top bolt hole stripped out, & the lower front bolt broke. Steering seems to be the theme of this event. At least I broke in camp. I'm glad I didn't try to follow Goatman up Chocolate Thunder as the sun was going down...
Matt
Rate This Thread:
8.25 carnage honda12 Modified Tech Discussion 18 April 15th, 2010 20:44
Carnage from TSF Roads NorthWest Chapter 27 June 23rd, 2006 09:04
Carnage run - 18 Mar Jeffro600 Colorado Chapter 3 March 19th, 2006 06:24
ARB Carnage. CRASH Modified Tech Discussion 7 July 21st, 2003 12:13
Carnage on the 'con. Jes Sierra Chapter 32 June 26th, 2002 20:50
