DK_XJ_1992
- Denmark
I have some trouble with my TC and I was hoping to get some advise here. It is a 92 4.0, with a AW4 and a NP242 behind. I have had it for 20 years. The last 6 years it has been parked due to long commuting distance. I have used those year to fix rust and other things. 6 months ago I got it back on the road and use it everyday (app 50 miles). Last week we had some heavy snow fall and I tried to engage 4wd. However, it for sure did not feel like it engaged. I tried all the trick with driving slow, shifting to N and tried both 4H part time and full time. Nothing seemed to work. The 4wd light never came on, but it has always been very unreliable. I managed to get home, put the TC back in 2H and parked the jeep for the weekend. Then yesterday all snow is gone and it is 55F. On my way to work and back it made some unusually noises. When I drove into my driveway I could feel the characteristic bump steer when you use 4H part time on dry pavement. So in some way it now when into 4H part time and refuse to come out, and I assume that I drove 50 mile on dry road in this mode. As it is my daily drive I removed the front driveshaft and replaced the TC oil with some Dexron II I found in my shed, so I could use the jeep today. This evening I had the chance to do some diagnostics. Both axles seems find there is no major backlash in the gear and no shavings or metal in the oil (Pic 1). The oil from the TC was dark, but did not smell burned nor had shavings in it (pic 2) (it had 1½ qt in it). It is not a linkage issues as I build a replacement some years ago with hemi joints, and the adjustment is spot on (pic 3). I feel all the position very well.
When the TC is in 2H by hand I can only turn the front drive shaft pinion counter clockwise. Shouldn't it run free in both directions?
When it is in 2H and it is turned it makes a rather loud noise (video). Is this normal?
When I change the TC to any other position then 2H I cannot turn the front drive shaft pinion by hand.
I really hope that I can get some advise, so I can consider some different options. There are no pull and pick junkyard where I live.
I do have the option to borrow another car if I need to take the TC out.
As I don't have enough posts to upload pictures they can be found in this link: https://drive.google.com/file/d/1B7Pq0ppnoXlZlp_wHXOYAKyjLu2AWp01/view?usp=drive_link
