Zips My 88 Heep DD
(1/4) plate, basically scrap I had..
(3/8) plate tied into the axle tube
Make sure the control arms you use or build will fit between the bolt and the skid. If they don't, make them...
Im going to sound bad for this but...
If I get the misalignment spacers for a 2 inch wide bracket would running washers to make it 2.5 wide be a bad idear?
probably.
ruff stuff makes wide misalighnmet spacer. to make a 7/8 hiem 2.5 wide. but they're not cheap at almost 7 bucks a pop.
Also got a turbo for trade for the super I have lieing around.
Get wheels and tires and lockers. Then turbo stuff later.
I need it to take the spot of the failed super. My dresser is gonna be weird with space on it.
Im working on it. Looked at some 33 today didnt like em.
:spin1:
I ripped off my glass pack that was a shocker. Floored then bamB it fell off tearing off some of the pipe.
Cleaning it up I burned the shit out of my hand.
Worked on my leaf spring mounts.
Boxing em in.
Also on the dana 30 knuckles bracing.
Worked on my bumper a bit, cleaned the inside some so it will be easier to weld.
33 mall terrains for $300 worth it? 50 percent plus tread and on d windows.
Plans before NAC fest.
33s.
V8 steering
8.25 in. (This weekend)
Finnish rear bumper.
Front bumper. (need moar recovery points)
Bedliner the floor.
Redo the bastard pack.
Put my stock leaves back in with the S10 mid and lower leafs then add a shackle.
This build is closed.
Is replacing zips. Its zips 2.0.
1998 classic
4.0L
AW4
Np231
Dana 35 I have the 8.25 almost done
Hp30
Im carrying all my lift stuff over except the rear leafs I am going to fix that a redo the bastard pack.
If any one needs any of this let me know
So far I have
Renix throttle body
intake
Throttle body
Doors $50 a peice
1 has been patched and bondo'd $15
Hatch $50
Tail lights 1 has a crack in it/a part missing $20 for the pair
Rustys lower control arms
Less than 1k on em $50
I have 2 I believe they are called echoes
Small curb damage Make an offer
I have turbines but I don't want to sell until I have my 33s so make me an offer
Good newish radiator $50
Old style e fan $10
Aw4 $65
Np242 $45
Rear drive shaft $10
Dana 30 hp housing $50 3.55s
Dana 35 I'll give you $5 to take it. :gee:
Header panel
$20
Grill $20
Fenders I dunno? They arent cut and one has some rust.
Willing to trade for parts
Currently looking for
Stock leaf packs
Passenger side tail light 97+
