HELP! Your opinion on 242 to 231 swap or rebuild?
Sorry this is so long but it getting complicated. Here is my problem. I've got the 242 in a 90 Limited renix 4.0, AW4. Some time ago the chain started slipping and has got so frequent that any serious pressure on it will make it pop like crazy and it also seems that at a side angle the chain slips off entirely until I let of the gas and it catches again. So it seems to me the chain is very stretched. Will the cogs be toasted to? Well either way I don't know what me best aproach is at this point because if I rebuild it/replace it/swap it. They all cost money it if I going to spend anything I want to be happy with my choice.
Also I plan on a longarm, axle swapage and 35s in the future if that matters. In addition I pulled the following quote off the Rubicon Express site and was wondering if anyone has experienced this or can explain it. "Over 3.5-inches of lift on a full-time NP242 unit may cause unacceptable vibrations on the front driveshaft, when driven in ”part-time” or locked constant use 4WD." I've got the 5.5 LA on my TJ and IMO its one of the nicer, better quality to price kits out there and Would like to put it an my XJ and that is why I mention the vibration blurb.
I am aware of most of the details involved with the swap, I think...?
1. Spline count(what year was the 21/23cut off for the 4.0?I think mine is 21...?)
2. input length(or will either work for an auto?)
3. need 231shifter plate
I am in the air to rebuild or swap. I've heard mix reviews about the 242 so I'm not sure what to do. I have a TJ and the 231 works flawless. It does NOT pop, shifts easy and smooth so that why I'm thinking about the swap. The drawback is I may get one from a jy I don't know the history or will this one have a half stretched chain? and it may cost more than me rebuilding.
How much am I looking at either way?
If my tranny is in fact 21 spline and I only can get a 23 case than I do have a 21 input gear available form a buddy that did a Vortec 5.3+ whatever tranny comes on that swap on his 4cyl YJ and used the AA kit to connect to the x-fer case. (Will that work?) Its not an issue having to pull the new one apart to change the gear because I want to do a SYE at the same time whether I rebuild or swap.
I know the difference is the FULLTIME selection with the diff but that doesn't seem important to me. I live in the desert and wheel rocks and dirt/sand mostly and never see snow unless its a snow run!
Maybe my 242 was just junk from the time I got it but it also never shifted as well as my 231. I had to really force it. Is that normal or is mine just junk?
Sorry for all the ?s but the more a research this the more confused I'm getting on what to do. Any help with my decision would by awesome. And maybe the most straight forward details on the swap.
