going stock wj steering, whatever that is lol stock tie rods and endsGoing OTK?
With the way you bend up stock steering? Might wanna hit the JY again for a spare.![]()
you may want to fab up a DOM tie-rod with some ruffstuff heims
my tie rods havent bent from impact and the wj tie rod is QUITE a bit beefier than the xj one. this is going to have to hold me over until i can afford something fancier.Ding Ding Ding!!!! :yelclap: Might be a little less likely to bend it up Dan... Key word... MIGHT! LOL
cant use it, i have a jk width axle and wj knucklesZj V8 tie rod is beefier than the stock xj tie rod that would be a good temporary one
howd you flip it?Not going to work with crossover.
I flipped mine, but the hot ticket is to use an aussie drivers side knuckle, and make a ghetto high steer
Drill/ goferit nutsert? for OTK? Heard a few people do the RHD dragink to run a cheaper OTK. But with the WJ crossover you could run it up top easy.howd you flip it?
I wish I could take the day off and help you. I am having withdrawals from grinding dust and welding smoke!worked my ass off today... got the rest of the brackets and gussets welded on the d44 and the shaft seals installed. the axle is now sitting under the heep, only the lower control arms are connected.
i also got the shock towers finished, and the front bumper modified so that the brackets fit over the frame stiffeners, and the bumper and steering gearbox is installed.
the air intake is finished, and the relay box has a new home, although still need to drill a couple screw holes.
the things i have left are:
make spacers for the unit bearings on the wj knuckles
install ujoints in shafts
install new ball joints and assemble knuckles/hubs/brakes
install steering linkages
make a track bar
make a new body side 3 link upper control arm bracket and weld it on
make 3 link upper arm and install
bolt in coilovers
make shock tower brace
hopefully i can put a good dent in all that tomorrow
